Where do I find the tension adjuster screw for the rear (of car) accessory belt. And where do I can access to it. I can see the two tensioner bolts and the adjustment screw for the front belt, but not for the back.
Secondly, has anyone had a problem with getting them to turn do to corosion or anything. I was thinking of spraying them with PB but if I get it on the pulleys or belt that would be bad.
Thanks
Thanks
