Failed Harmonic balancer
ThrillSHO
Wake Forest, NC, USA
Anybody had this problem? The outer damper has seperated from the inner hub, chewed up the belt and scuffed the back where it rubbed the block. I was able to slide the outer damper off by hand. When I pulled the inner hub off, I noticed radial cracks across the pulley groves. I've had this off twice in the last 4 years and never noticed any problem. I've always used the proper puller - pulling the center using bolts, never from the outer edge.
Anybody know if the MTX damper is different from the ATX? I know the MTX uses 2 belts, but the ATX has two belt pulleys and uses only one. Maybe they are the same?
Anybody got a damper laying around? This is terrible timing - I have paid for a 2-day track event next weekend.
Thanks for any input!
Mr Anonymous
Tire Wall
Check AutoZone.com and RockAuto.com I'm pretty sure both can get them for around $80 new (aftermarket).
