factory sub
92sho16
b00sted
Liverpool, NY
what the impedence(ohm rating) on the factory sub? My meter read 5.3ohms but i know my sub is badly blown and this effects the reading.
Bizzy
I had asked a question about the JBL system a wile back relating to this. I got the answer that the speaker were 6ohm. I would think that the sub would be the same ohm load as the other speakers in the system.
DJ SHO
NY
Yes the NOMINAL IMPEDANCE of the factory sub is 6 ohms, but it will most likely read less on a meter. Speakers tend to read less on a meter than what is stated. My 12" Soundstream SPL subs are DVC and each coil reads 3.8 ohms.
92sho16
b00sted
Liverpool, NY
I figured it was 6 but my sub was pretty badly blown and when a speaker is blown the impedence generally goes down considerably. I have a 6.5 sub from my other car that a friend blew and it doesnt even have any resistance.
Does anybody know where you can get a 6.5 sub with a 6 ohm coil?
92 Blue MTX
Removed Air silencer
White face gauges
60k soon
If the speaker coil blows it opens up and you will get an infinite reading. Usually speakers coils are either good or open.
Most coil ratings are a nominal rating. Whatever the meter reads is the actual reading. How would you get a true reading if it wasn't with a meter?
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
SHOZ123:
That all depends on if you are using a DMM or an analog meter...
DJ SHO
NY
NotSoSlowSHO:
SHOZ123:
THey still have analog meters? :D That's like asking someone if they use their 8-track player still.
If you're wanting to replace the 6.5 inch factory, this topic has been gone over a hundred times. Search and you'll find recommendations for a good replacement. Since you probably won't find a 6 ohm sub anywhere, putting a regular 4 ohm'er in there isn't going to hurt anything. The factory sub amp is supposed to be rated at 85 watts rms @ 6 ohms but it's not putting out that much power. So by dropping the inpedance a little using a new sub it's not going ot hurt it.
<small>[ February 13, 2003, 02:22 PM: Message edited by: DJ SHO ]</small>
