K-Dawg
Replaced the cam seals, among other things, on the 95 today, mostly as as a preventative measure while replacing the leaking water pump.
Anyway, I guess I got a little bit too confident in my abilities while removing the exhaust cam seal and nicked the aluminum on the head. I think I removed enough aluminum in the right spot that the new seal is going to leak. I went ahead and buttoned everything up, hoping that its not going to leak, but I have a feeling that it will. I drove the car for a couple miles, but couldn't tell that it was leaking (I didn't look hard).
Anybody found a decent method to cure a leak here caused my stupidity, other than replacing the head? I really don't want to have oil leaking all over the place on this car, because everything is so clean underneath.
BTW, I'm ******.
BTW, I'm ******.
