B7 Quattro Man
I have 90% of the needed gaskets to fully rebuild my 3.2, I had the walls finish honed, the heads decked about a year and a half ago. If I take the block and heads back in and everything specs out, would it be ok to use the stock pistons when wanting to run a turbo?
I have, rod, main, thrust bearings, valve stem seals, 3.2 head gaskets, full upper and lower 3.2 gasket sets sct. I will buy all the still needed parts when I figure out what they are, soon hopefully, and buy sensors as needed.
TIA
TIA
