Extreme-range alignment parts?
wuzzzer
MN Moderator
St Cloud, Minnesota
Anyone know of a good source for alignment parts that will allow 'extreme-range' adjustments?
Something that will adjust up to 3 degrees of rear camber and 2 degrees of front camber?
RStalveyARFF
too many shos
Georgetown, MA
I need to know what you're talking about here. 3 degrees of positive? I have a kit right here that I can't use, because I thought it did both negative and positive, and only does positive. As for the front, you'll just have to enlarge the holes, there's no eccentric front mount yet for the Gen III.
wuzzzer
MN Moderator
St Cloud, Minnesota
Yes, currently my rear left wheel is -3.1 degrees. I need a kit that will allow a positive adjustment of up to 3 degrees if possible.
DeaconBlue
Cleveland, Ohio
Try the TRW p/n 13235A ecentric rear trailing arm bushings. They allow up to 4 degress of adjustment. Each kit contains one (1) bushing so you will need two (2) kits to adjust chamber and four (4) to adjust chamber and toe. They are installed in the center H-box end of the trailing arms.
BTW, did you check to see if you have a bent trailing arm ?
