Exhaust Unit
Stracey R
I want to swap my exhaust unit with a lower mileage exhaust unit in great shape. The only difference is, the lower mileage one has a flex pipe, mine does not. Will it swap directly to my '92? How about the hangers, whats holding the exhaust unit in place, 3-4 rubber mount hangers?
Thanks
Racer X
SHO Pilot, Retired
Connecticut
If it has a flex pipe, then it more than likely is from an ATX SHO and not an MTX. I don't know whether or not it will fit in an MTX, but I wanna say that it will be slightly too long, since the 3.2l sits further forward than the 3.0L does.
I think the rear hangers are the same however.
Stracey R
Its from an atx with an mtx resonator and recently new mufflers. Can anyone verify this if it will bolt up fine?
Thanks
pjtoledo
'ol man in the SHO
toledo,ohio,usa
I think the front exhaust manifolds are different between ATX and MTX. That would mean the two points where the Y pipe connects to the manifolds are a different distance apart. I'm not the least bit positive on this, can anyone verify it? Also, the Y pipes are different under the oil pan, the wrong pipe may hit the oil pan. Do some research first to be sure.
Perry
Stracey R
Well I figured that, the engine blocks are basically identical. The only main differences on exhaust setup is, the y-pipe and the rear exhaust manifold for an atx. The atx has an egr connection on the rear exhaust manifold. In this case, I have an mtx already, wasnt sure if it the catback was identical, i think it is, just cant find any topic on it.
Xs SHO 1
Unknown
McHenry, Illinois
I don't see why it shouldn't fit, worse come to worse, just replace the flex pipe with a shorter unit it its too long/short a couple of inches. Muffler shops shoud have those on hand....
