Hello all. I am new to the site and am looking for advise from any SHO veteran who has encountered this problem. I will try to be as specific as possible.
Problem: At constant speed between rpm ranges of approxiamtely 2000 to 4000 rpm my car exhibits ecessive engine braking (stumbling sensation)when driving at a constant speed or when adding slight throttle to hold constant speed. The tachometer drop is anywhere from 1000 to about 1800 rpm. The tach and engine for that matter becomes erratic. It is a simular sensation to being in the car with a new driver learning how to drive a car witha manual transmission whom is popping the clutch without letting it out smoothly enough. The only way to stop the stumbling sensationis to either accelerate, downshift and incur an accelaration in lower gear, or let of the accelerator altogether. The problem is reminescent to a situation called full-cut I have experienced in my eagle talon at high RPMs.
My inital guess was a faultered mass air flow sensor or a fuel delivery problem. However, I would think the fuel pump being electric that the fuel flow scenario is unlikely or I would have problem during acceleration too. A throttle position sensor makes sense but I havn't replaced it because when i scanned for codes I got nothing.
To date I have done the following.
1. Checked for loose wiring, dirty connectors
2. Replaced MAF Sensor
3. Cleaned the IAB/ISC
4. Checked spark plugs for arcing
5. Tried Fuel injection cleaner
6. Tried new gas
7. Tried clearing the memory on the ECU
A final note. This problem seemed to start right after replacing the entire AC system. I know there are a few connectors on the back side of the engine that are in the way when trying to get to the evaporator inlet for the liquid line. Coincidence this just started or not?
Any ideas out there?
I have run the codes and I didn't get a single code displayed. I could hear the code scanner running its checks, but it gave no indications afterward. I always though it was supposed to at least display 12 if there were no faults found. Perhaps I need to try again.
<small>[ August 01, 2002, 11:57 PM: Message edited by: aviator22 ]</small>
6. Tried new gas
