Evap system Garage smells like fuel
bad_4dr_sho
Now what broke
Dickson, TN
Hello all,
I got a full tank of gas, and then put the car in the garage for a few days. I noticed yesterday that the garage smells like fuel. I went to start the car to move it out of the garage and the car feels like it has a really bad misfire/vacuum leak. It had a hard time getting about 10-15 mph. Check engine just shows O2 sensor codes. I'm guessing its something to do with the evap system. I see that there are 3 common parts that go bad, the evap canister vent valve, canister purge valve, and the canister itself. Are any of the cars symptoms more common with a specific part failure?
2014 SHO PP
Thanks
kryptto
South East, Florida
Did you pull any codes other than a MIL for O2 ?
I pulled the TSB for the 14 and we'll see attached to see if it helps.
  • Fuel System - Raw Fuel Odor Near Intake Manifold - ALLDATA diy.PDF
