Estimated HP? And Awhp?
Corey Sig
2011 SHO PP
MD
Hoping someone can get me an idea where my car will be at. 2011 SHO PP. Intake, cat back corsa exhaust, 3bar map, 170stat, plugs .30, 93 tune from torrie, and stage 2 meth (about to be installed very soon) Thanks guys
Usmcsho01
Yea I was quoting crank numbers that was my estimate figure 380 wheel 25% loss 475 crank?
Sent from my XT1650 using Tapatalk
OmaHahn
Omaha
It's got to be a heck of a lot more than 475 crank! Our stock SHOs are 365 which is on the LOW side of actual HP numbers at crank. All of his mods you're telling me only 100 HP more. No way!
yo tony
Manning, SC
Well the tune adds bout 50 and so does the meth. Exhaust and intake are noise fluff. That's a lot of damn horsepower lol
Usmcsho01
You have to figure also being a older vehicle your not gonna put out the best HP. So I was being conservative. What do stock shos put out for HP usually
StealBlueSho
NA
They loose around 21%-22% from crank to wheels.... The tunes are advertised to add 50+ to the wheels... Just FYI... Check out the dyno section on Ecoboostperformanceforum.com...lots of answers there...
2012korn
Depending on how aggressive his tune is, 400ish whp before meth is possible. Adding downpipes would help that number. With meth and downpipes I'd say in the 440whp range and most likely a bit more
