Ta2dResqr
LTFT? STFT? FRP Desired?
Will do. I hate vacuum leaks.All the pids look ok. Check for a vacuum leak.
I do not know those acronyms sir. Please break them down for me.LTFT? STFT? FRP Desired?
No apparent vacuum issues. I checked from top of engine with engine cover off. Followed every vacuum line I could find. They all look great. Car only has 38,000miles on her.All the pids look ok. Check for a vacuum leak.
check the plastic charge pipes as well for cracks.No apparent vacuum issues. I checked from top of engine with engine cover off. Followed every vacuum line I could find. They all look great. Car only has 38,000miles on her.
Long Term Fuel Trim, Short Term Fuel Trim, Fuel Rail Pressure Desired, which is OK per your picture.I do not know those acronyms sir. Please break them down for me.
STFT = Short Term Fuel Trim, will show if it is immediately rich or lean.I do not know those acronyms sir. Please break them down for me.
LTFT = Long Term Fuel Trim, will show if it is a constant issue or more intermittent.
FRP Desired = Fuel Rail Pressure Desired, your picture shows rail pressure but what is the computer commanding. This will show leaking injectors, weak pump, etc.
Sometimes going back and looking what we thought we fixed is the least but unfortunate suspect. Sorry to hear about the problem but glad it's hopefully in the rear window now.So I had a failure. The hose that attaches on the bottom of the top plate had come loose because I must have missed the clip on the ***.
The car puked out about a gallon of fuel that I saw. I imagine that balances the saddle tanks and I had an overflow? No matter.
I did reset the car's PCM completely like a ********.
She's running much better now with a slight noise from the new fuel pump and an occasional stutter on let off at mild throttle. I hope she's just relearning!
I would like to thank you all kindly for all of your help! I would've been stuck without you! Forums like this are about the only good thing with the internet.
THANKS!
Sent from my SM-S908U using Tapatalk
