The back probe is at the coolant gauge temperature sender.
Two ways to see what the temp is when the fan turns on. One is an IR temperature checker aimed at the t-stat. Not entirely accurate.
What I do is when flushing the radiator and it is full of straight water is to disconnect the upper hose, open the radiator cap and with a garden hose make sure it stays full. Then let the engine run checking the temp of the water coming out of the upper hose. This accurately test both the t-stat and the ECT assuming you have an accurate thermometer.
. . . .how do i know if the engine temp is accurate?![]()
This appears to be hopeless.......![]()
