professorkaos93
rules the world
sometimes when i am accelerating, the car will act like no fuel is gettin to the engine, i need this fixed, cuz its annoying...any advice?
==========================================================professorkaos93 said:does anyone know what this could be?....its buggin me![]()
or have you sprayed you engine lately in any car wash ?? if so maybe water has goten in the wires or the plug holes... also you should use fuel injector cleaner every 3-5 k miles regularly, that helps a lot.. i was thinkin that it had somethin to do with the injectors, but i didnt want to do anything with out knowin what to do, and i might need to use some fuel injector cleaner thenEndri_SHO said:==========================================================
maybe a cloged injector????or have you sprayed you engine lately in any car wash ?? if so maybe water has goten in the wires or the plug holes... also you should use fuel injector cleaner every 3-5 k miles regularly, that helps a lot..
good luck
...and thank you Redline said:Also, make sure your MAF is clean. That can make a difference. Might be a good idea to replace your fuel filter if that hasn't been done in a while also.
no noises....SeanMc said:Mine is doing the same thing. Check to see if your fuel pump is making funny noises (rrrrrrr, bzzz, whine).
