engine stutering...
professorkaos93
rules the world
cinci.
sometimes when i am accelerating, the car will act like no fuel is gettin to the engine, i need this fixed, cuz its annoying...any advice? :cool:
Justin101
It's A SHO Thing
Rocky Hill, Connecticut
i am having that same problem with mine on cold starts, very sluggish, and sometimes when i go to punch the gas, i think when i had a 73mm MAF i F'ed up my engine, had it like 2 weeks and sold it on ebay! :bonk:
Endri_SHO
SE 300 , S 500
IN THE MERCEDES-WORLD
professorkaos93 said:
does anyone know what this could be?....its buggin me :cool:
maybe a cloged injector???? :oogle: or have you sprayed you engine lately in any car wash ?? if so maybe water has goten in the wires or the plug holes... also you should use fuel injector cleaner every 3-5 k miles regularly, that helps a lot..
good luck
Redline
Fire It Up
Sandpoint
Also, make sure your MAF is clean. That can make a difference. Might be a good idea to replace your fuel filter if that hasn't been done in a while also.
professorkaos93
rules the world
cinci.
good luck
i was thinkin that it had somethin to do with the injectors, but i didnt want to do anything with out knowin what to do, and i might need to use some fuel injector cleaner then :biggrin: ...and thank you :thumb:
thanks, and i dont think it has been changed, but it might have been when i had my new engine put in...
professorkaos93
rules the world
cinci.
SeanMc said:
Mine is doing the same thing. Check to see if your fuel pump is making funny noises (rrrrrrr, bzzz, whine).
no noises....
i have put fuel injector cleaner in it, twice...still messin up...havent done anything with the MAF yet, how would i do such a thing?
