High pitch noise through the radio, changes tones with changes in rpm. You can even hear it with the volume turned all the way down, but not off.
This system has been in three cars, and the SHO is the only one that has this problem. It a Kenwood reciever (10 yrs old),an EQ, and a couple of amps. I checked all wiring to the amps and reciever, replaced patch cords to the amps in the trunks, tried installing a "ground loop isolator", nothing helps.
I'm using the wiring to the factory radio to power the reciever and EQ. (ign,batt,grd)and have a seperate battery cable to the trunk for the amps. Any idea what is causing this? Any guide lines on where to go from here would be greatly appriciated. I am about ready to buy a new head unit and eliminate the EQ and the FM CD modulator and have it all built in.
John
89 SHO
John
89 SHO
