lincster2
Hey there... my 92 mtx was knocking, knocking really badly, loudly banging. I guess 1 too many races to the redline done her in. So I bought a used engine from a local wrecking yard. Had my mechanic compression test it, all good so out with the old and in with the new....well new to me. This engine seems to run a little rough..just like the old engine..bought the car about 2.5 years ago. Question No. 1 are the sho yamaha engines suppose to be a little rough running? Question No. 2 there is a little bucking between 1,800~ 2,400 rpms every gear. New spark plugs, timing belt installed. The former boy racer owner had a performance chip installed....pulled a 511 code k.o.e.o. so I removed the chip, tested again no code...does this mean that the chip is bad or just non ford chip was installed? The master plan is to take the sho the a dyno tuning/custom chip shop to see what they can do. They told me that they have all sorts of testing equiptment so if it has a bad sensor of some sort it come to their attention. Please chime in with some thoughts...I report back after the dyno experience. Thanks
