engine light with regular octane gas?
kevingotashotoo
200 or so ponies
peterborough,ON canada
dad put regular in my sho, engine light comes on for a bit under some decent
acceleration, is this my timing being ********?, havnt checked my codes yet
but its coming on when i accelerate quick, just wondering if someone had this problem ??
Minnesho
i was wrong
MinneSHOta
A stock SHO will run just fine on 87 octane. it may take the computer a few trip cylces to relearn it but it shouldnt cause a MIL to illuminate.
kevingotashotoo
200 or so ponies
it just stays on for a bit then goes off, and i havent noticed or felt anything wrong with the engine so i think im good to go, may something was stuck open or was out of range or something
projectSHO89
SHOless In St L
My 89 has only gotten 87 octane in the 4 years and 54k miles I've driven it.
Pull your codes and see what the memory codes are.
Steve
wood_e
The dude
Ames, IA
kevingotashotoo said:
car runs fine though
Honestly... that doesn't mean something isn't wrong. Your computer is giving you a code because it has found a fault in the system. Check them and see what comes up.
I run my SHO on the cheapest gas and it runs fine.
Sh03d
Sho Ed
Fairfax VA
Check codes, buy my guess is the 02s. The check engine light on my 95 with bad 02s would come up twice as much with 87 octane then 93.
projectSHO89
SHOless In St L
ran my codes this is what i got
116
114
519
so there for my raditor coolant sensor was out of range
IAT was clogged stuck upen
psp circuit switch
If the engine was cold (not at operating temp) and the ambient was below 50F, that will explain the 114 & 116 codes.
Steve
