Engine Leak Q
SHOv6
Findlay, OH
I've noticed for the past week that after I would drive my 94' ATX SHO and the engine was warm I could smell burning antifreeze. I don't see any on the ground where I park it. Is there any place I should check for leaks that are common on the SHO? Any advice you guys could give would be much appreciated! Thanks
greenbeanmtx
King Skidmark
Waco Tx
I had the same problem but it was on a camaro i had. turned out it was the intake manifold gasket seaping when hot. It never leaked onto the ground either. Id check everything on the top end and see if you see any moist spots.
Dumb question but have you noticed a coolant level change?
