Engine codes
GT86
Florida
I finally got my car put back together after the changing the timing belt
Now I have some codes I'm not sure what they mean
I did the self test indicated on this site
http://www.shophoenixproject.com/eec/eec.htm
Here's my codes
172 (R,M) Oxygen sensor not switching - system is or was lean - Single, Right orr Rear HO2S - Fuel control
I believe this means i need to change the oxygen sensors
332 (R,M) EGR did not open/respond during test or if memory code, did not open intermittantly - EVR or PFE
I'm guess this means I need to change the Egr valve
538 (R) System did not receive "goose" test
Have no idea what this Means
632 (R) E4OD - Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test
Not really sure on this I'm guessing the TCS needs to be changed
565 (O) Canister Purge 1 solenoid/circuit failure - Solenoids
No clue what this means either
CerberuS
300 HP N/A SHO
Granby, QC, Canada
Most likely the rear right O2 failed.
Canister + egr = same issue
Goose + TCS = same issue
Look for unplugged wires behind the intake , near the EGR.
TCS one i have no clue.
But it doesnt mean it NEEDS to be changed. sometimes some codes can be erased just by cleaning the faulty piece
Rockledge
Pluggin' away
Connecticut
The canister purge valve is a part of the EVAP system and therefore not related to the EGR system. The 565 code could be a bad canister purge valve or a problem in the CANP circuit (open, short).
As noted, the 538 and 632 codes, and maybe even the 332 code, can be attributed to not executing the EEC Self Test in precisely the correct manner. Pulling EEC-IV codes can be tricky at first.
If the 332 code was not caused by an error in the EEC Self Test, then it's more likely attributable to clogged EGR ports/nostrils. (See: http://www.shoforum.com/showpost.php?p=619933&postcount=3). EGR valves rarely fail.
The 172 code may indeed be a bad 02 sensor.
I agree with the suggestion to triple check all electrical connections and grounds.
shobroooo
