Engine Codes
Baroa
Cheshire, CT USA
I ran the KOEO and KOER tests and got the following codes: KOEO = 113, 542 KOER = 998, 113. Any ideas as to what these mean and what the problem(s) might be? Before I put the car in storage (about 7 months ago), the check engine lite wasn't on. I just completed 60K and replaced the clutch. The car is running fine. Thank you for the help.
SHOemup
Dalton, PA
KEOE KOER=113= ACT indicated -40defF. cicuit open. (ACT = Air Charge temperature
KOEO = 542 = fuel pump secondary circuit failure.
I got These at www.shotimes.com. They didnt have anything for 998.
My source shows for 998:
998 (KOER) Did not pass Key On Engine Off test yet (Get 111 in KOEO first)
(KOEO) Transmission Electronic Pressure Control (EPC) solenoid/circuit fault - Transmissions
Scott
