I broke mine in on the street. I think I read that same article back in the day too... I remember firing it up, and immediately took it out to the road nice and easy then put her in second and let her have it, then third and did the same... then I let it ease itself back down...
I did that for a while until she was warm, 10-15 min or so then when I got close to the house I ran it a little further into the red.. (wasnt too worried with the udps on there)..
I had some guy tell me once it was nice and hot to do that.. .run it a little past where you would normally run it, because once the pistons and rods are as hot as they are going to get they stretch a little and you want to make sure they get seated all the way to the top of the cyl. Reason being... if you don't do that on break in, and then miss a shift or something later... there could be a little 'ledge' on there that could chew into your rings, then cause them to leak after that..
Just what I heard.. and how I did mine. After that first time it ran, I changed my oil, ran it again thru a heat cycle, changed it again. Was nice to it for 1000 miles or so, swapped to synthetics at that point, and normal intervals... car hasn't leaked or acted funny in 20,000 miles... 30 mpg on the highway...
Sounds like your oil change plan.. lol
