Engine and transmission mounts help
Bessemer, Alabama
Sure would appreciate any help deciphering how many engine and transmission mounts are there on my 95 5spd. Part numbers would also be great. My vin is 1F starting. Thx so much guys
sperold
Last to Know
Check on this forum for information on reinforcing the front mount with a 2 part epoxy and a bolt.
If you buy and install a new one, don't throw away the old one.
Irish Pride
Irish Inside
MusicCityUSA
Part numbers will do very little. The front mount is long obsolete. Your only option for a replacement front mount is to rebuild the one you have or buy a reinforced mount from a place like shosource. The rear mount and trans mount should be available at rockauto. Rockauto might list a front mount for your car but trust me, it is wrong.
itwonder
VA
This: http://www.shonutperformance.com/
Click on Motor Mounts. The table lists the obsolete Ford part numbers. Click on the Performance link. Bite the bullet and buy the SHONut reinforced front motor mount. The part quality is crucial, and SHONut's part is worth the price. Find the rear motor mount at Rockauto; it's cheap.
