Eibach Springs
tonypipes
NY
Can someone tell me if the Eibach Pro-kit springs that fit the 2010-2012 SHO fit the
2013- 2014 SHO PP Part #35124-140 Thanks
Sleeper4SHO
Speed ******
NJ
call Eibach directly...they have great customer support....and if you find out the answer is no, and you have a set off eibach springs for 2010-2012 PLEASE PLEASE let me know. I have the rears and have been looking all over for the front springs. I would be wiling to buy them off you. Eibach no longer makes them.
tonypipes
NY
I think they will work out , H&R list there springs as the same part number from 2010 and up meaning no changes in years.
I called Eibach tech line, they only tested them up to 2012.
said that if H&R uses the same spring on 2010 and up models it should probably be fine. I'd like to here from someone that has installed these springs on the newer SHOs to be sure.
