Eibach Koni Combo ?
shomanv6
7000RPM
baltimore,maryland
I am curantly getting this set up for my sho while Im getting that done what other mods could I do .such as poly bushings all around or something?also where do you get the camber kit so your tires dont wear unevenly?any suggestions would be apreciated.thanx :salute:
38SHO
#1 Oil Abuser
North Palm Beach
there are camber kits on ebay right now.....
buy a cheap 95-01 i think FRONT DODGE NEON STRUT TOWER BAR off ebay for like 25 bucks with shiping, put that on the REAR of your SHO. CHEAP, EFFECTIVE
ALuminum Subframe Bushings are awesome for the money........
there are also some cheap Subframe connectors on Ebay right now but I don't have any personal experience with those, can't be bad though.
Polyeurethane HD rear endlinks are fairly cheap mod too...
bushings can be expensive and a PITA to install. I would do the above mods first if your on a budget, if your not on a budget find some Rear control arms and an H-brace, I just bought that setup and will be putting it on shortly and I can give you a report on how that works out. My complaint is my SLO has a real floaty rear suspension, could be those cheap *** suspension arms, could be my 90k stock struts with saggy springs....... I will find out soon LOL.
shomanv6
7000RPM
baltimore,maryland
thanx.... update me on how your install works out.I think I am going to go with aluminum subframe bushings.then subframe connectors but I need to find a shop in baltimore that can do it.
38SHO
#1 Oil Abuser
North Palm Beach
take it to a transmission shop and ask if they will install it, as they are used to dropping subframes on cars....I don't know my car is from south florida and has no rust underneath at all.. so it was quick and easy for me to install my bushings... could be different story for up north car.
SHO_Diehard
Houston, TX
Get ready for the noise...
I have delrin SFBs on my '89. I thought they were way too noisy when I first installed them. I don't think about it now, but the noise is of course still there, along with the wind noise and moonroof rattles. If I ever get around to fixing everything, the delrin may have to go.
I bought some gen 3 bushings for the '95 MTX from JoshT, hopefully by the end of this weekend I'll know how they work. :naughty:
