Ecu
vance580
monroe, mi
Is there a way to test it cause I think mine is bad if you want to know the details then Read Here . Also is 220 a good price for a remanufactured one with a 1 year warranty?? But I'd like to test it before I dump that into it after all the other stuff I've put in.
Thanks for any replies
shonutt
Yeah I Got Rice
Saginaw MICHIGAN
Not To Bad A Price..got Mine Frome Carquest Had To Be Shipped Cost Me 178 Plus My Old Unit.. With Out The Old Unit 278..
Mr Anonymous
Tire Wall
First, a good used PCM shouldn't run more than $50-$100 depending on what code you need/find. You could try posting a WTB in the appropriate section, just be sure to mention year and tranny.
Honestly though, PCM's rarely fail. I'd be willing to bet that something happened with all the work you've done that is the true source of your no-start. Presuming you're now getting fuel, spark, and air as you mentioned in your other post, I suspect you may not have the timing belt on properly. I have seen this on several occasions where the car won't start despite everything seeming fine, and eventually found the timing belt off by a few teeth.
I recommend pulling the timing covers and triple-checking timing belt alignment again, to the point of removing it and re-installing it to make sure all the marks line up properly. People have inadvertently put the timing belt on backwards on more than one occasion, or lined up the marks incorrectly.
vance580
monroe, mi
is there a way to test the ecu so i can test that first before ripping everything apart. My timing belt shouldnt of jumped teeth cause i cut the old one off length-wise and slid the new one right on with out no problems lines lined up after was done. But if I can test the ecu and eliminate that as a problem the I'll recheck the belt.
TYSHO
Earth
Remove the harness, inside the engine compartment, and see if any pins are broken/loose.
When I pulled mine, I had pins stuck in the harness, with wires sticking out.
AL
ny
a of mine friend has a 93 SHO and wants to me to change his ECU, where in the car is it located?
do i need a 93 MTX ECU, or will an 2nd gen ECU work?
thanks in advance, al
edit; " You last visited: 12-31-69 at 11:00 PM " 1969! :D
