SHODWN
Mother Threasa
Well I got the car back Monday (they called Friday but I was out of town)
It was covered under warranty!
Lots of stuff happened to it and I need to read some to get a good descriptive answer..
No 4-5-6 gears (first issue) - answer OD clutches were missing, and direct clutches burnt.. Tech said I had all OD steels and no clutches. Found them in the filter..
No movement, partially from 4-5-6 not being there as limp mode puts it in 5th.. No 5th no move (electronic and mechanical failure)
TSS..(turbine speed sensor) Bad.. electronic and talks with LPC (line pressure control) No line pressure, again, no move..
TRS (transmission range sensor) BAD . self explanatory, (also talks to TSS and LPC) but this is why it would fall into park why the 20 of us were trying to push it up the trailer and why it did it on the way off the trailer..
Start clunk- this is what I need to still figure out.
Whirling noise, thought to be the TC (torque convertor) was the OD clutches 4-5-6 just spinning.
TRS- is a known Ford problem and there is a TSB already out for this.
TSS- is also a known Ford issue and I don’t believe there is a TSB yet, but read 100+ other complaints on this.
I think the TSS failed first, allowing the LPC to loosen its grip and was slowly was having a melt down. Once the clutches slipped enough creating even more heat in the trans beside the already ridiculously hot conditions outside was the ultimate demise of this trans, after parking the car and letting it sit (boil) is when the TRS decided it too wanted to join the party of “no longer working”..
The Trans received a Master overhaul kit (all clutches and gaskets) A new updated TRS and a new TSS, Filter and new fluid.. But during all of this I read the trans section of the factory service book and the cooling parts as well, I figured out how they cool the trans. The old days they used the radiator end tanks to cool and maintain the fluid temps (cool is always the joke) and this would work for the average person, but for the people that want to use the car (SHO- Super HIGH OUTPUT) for its intended use---à FUN then will have to go back to common SHO knowledge and add TRANS COOLER/s. They now use the Ac/ condenser end tank to cool/ maintain the fluid temps and included a thermal bypass again.. So needless to say in short order the Trans cooling system will be modified and will eliminate the Ac condenser out of the plumbing and also remove the thermal switch (used for heating the trans fluid faster in the winter. I don’t drive mine in the winter) and plumb in a nice large cooler, and a trans temp gauge seeing that either the TFT did not work or was miscalibrated because there is a temp warning event that is supposed to notify you that your trans is to dam hot.
I have more to add on my feelings on this car, Still mostly positive at this point, but just disappointed that the car failed on its second time to shine.. at this point I don’t think that car will be able to attend the convention next year, I don’t want to tow it home from Minnesota. But a HUGE thanks to my buddy Don Mallinson for wanting to race my Chevy Diesel vs his EcoBoost f-150, even though he chicken out he saved me 500-1000 in airfare and towing expenses. Thanks DON! I would have whipped your butt anyway.
First time driving it without a tune in almost two years reminds me that tune are great!
