ECC codes
HoustonSHO
Houston, TX
Ok, after I took my 93 ATX SHO to a "buddy" mechanic, he said it wouldn't get past the throttle snap phase....yet I just figured out how to do the test myself and everything went ok...hmmm...anyway, here are the ($h!t load of) codes....
KOEO:
124
172
173
212
214
332
634
647
648
KOER:
332
129
167
225 (not cont.)
536
632
I read what the codes mean, but I'm not sure on how exatly it is related to a partiular problem. Any help much appreciated.
Thanks,
Aaron
None of us have the codes memorized so you're going to have to elaborate more on: 1- what are the problems and ; 2- what do the codes mean.
I mean, I'd go find the meaning of a problematic code but you've already looked. So how about a heads up?
People, people help us help you.. he he.
<small>[ June 10, 2002, 03:41 PM: Message edited by: luigisho ]</small>
projectSHO89
SHOless In St L
Here are the codes. Look them up.
http://www.shotimes.com/SHO3eeccodes3.html
With that many codes, you'd be better off resetting them, then driving until your CEL comes on again. Fix that problem and wait for the next.
You have codes that indicate problems with almost every sensor under the hood, plus some that indicate an improperly run KOER test.
Start over.
Steve
89
Heathcotejosh37
