12valve@heart
Hope all had a Merry Christmas. I'm a noobie to this forum and to SHOs in general. A couple months ago we purchased a '94 SHO Automatic that had the 60K maintenance done about 5K ago.
In the last couple weeks, the car has started to misfire intermittently. By that I mean that sometimes it will run perfectly but then suddenly it will start misfiring and will continue to misfire for varying periods of time. Sometimes less than a minute but sometimes for extended periods of time. As an example, yesterday the car was running fine when we pulled into the pharmacy drive-thru and continued to idle fine for over 10 minutes but then suddenly started misfiring and continued to do so for the next 10-15 minutes both while sitting in the drive-thru as well as while driving home. It happens both when the engine is cold and when hot. When it misfires, I notice that the tach drops by several hundred to over a thousand RPM. I also have noticed a gassy smell and the transmission does not shift normally although that could be related to the RPM change. I also noticed the other day when it was warmer outside that the car started to get warm like the cooling fans were not working. I did verify that the cooling fans work when the AC is on but haven't verified the temperature switch for the fans.
I jumpered the EEC today with the car near operating temperature and got the following codes:
KOEO
172
173
181
216
KOER
213
538
536
521
632
A search of this forum lead to several potential issues but I thought I'd ask for input before I start changing out parts. I'll admit up front that I don't have much experience with troubleshooting automotive electronic controls (my expertice is more in the area of mechanical diesels) so any suggestions or guidance would be welcome.
KOEO
172
173
181
216
KOER
213
538
536
521
632
