EBC Yellowstuff Correct Part Confirmation
cole3498
Alberta, Canada
Just had EBC Yellowstuff pads delivered, I’m finding their website no longer finds this part number or finds anything for the SHO. The rear pads look like all the photos online, but I can’t find anything confirming these fronts are correct. Based on measurement and part number in this photo, can anyone confirm?
Fd2e50e443ffbf1ccd9715b2016a0f58
I’m not going to be installing them until April, so I want to confirm while I can still return if needed.
Texas Marauder
Lone Star State
There are 2 front pads listed for 2016. DP41873R and DP43019R (noted with clips)
AFAIK, DP41873R is non PP, DP43019R is PP.
(Edited because I misread a rear pad as a front pad)
cole3498
Alberta, Canada
There are 3 front pads listed for 2016. DP41873R, DP43019R (noted with clips) and Police DP41887R (noted with clips)
AFAIK, DP41873R is non PP, DP43019R is PP and DP41887R is the same as PP with a different friction material, probably more aggressive and/or heat resistant.
Interesting, I’m in Canada and ordering through Tdot Performance. Their site had the DP41873R fitting only the Limited/SE/SEL, not the SHO. Perhaps I’ll reach out to them to confirm why their site says that.
kryptto
South East, Florida
I have emailed vendors several times, and a great way to confirm.
as an aside, you will like the yellowstuff pads. @bpd1151 used them on his SHO before moving on to Wilwoods. i use the Orangestuff on our Edge and they work great.
Boochy47
Michigan
Ebc yellow stuff and ebc dimples and slotted rotors best breaks I’ve ever used hands down
bpd1151
Lurking Around
SHOcago 'Burbs
EBC yellow stuff and EBC dimpled and slotted rotors best brakes I’ve ever used, hands down
Customarily, I would've agreed with this statement wholeheartedly, as I rocked the same setup.
But the ending part of "I've ever used hands down" is a statement I feel compelled to comment on.
Why?
Because I would've stood by that unequivocally until I myself rocked the BBK from Wilwood.
Light years difference!!!!
Factory brakes: Replace immediately.
PI brakes/pads vs Factory: Better.
EBC Yellows vs PI brakes/pads: Better x2
Wilwood vs EBC: Creme De La Creme
Sent from my SM-N986U1 using Tapatalk
