TAM
Hey folks -
I bought a '95 hard button eatc, installed it in my '93 sho and seemed to work fine. Then suddenly the eatc thinks it is -5 to 15 degrees outside! SO you get heat baby (and plenty of it) unless you throw it to mac a/c.
I took a look at the outside ambient air temperature sensor in the front of the car and it is hanging there kinda loose and wiggling around a lot. I try to pull it out of the socket to look for moisture and naturally I make some dumb mistake and I broke one of the clips that holds it in tight. Gave up and decided to regroup for a moment.
Just in case I ordered a new sensor from FPN I'll get next week. When I install it (surely I won't break the other retaining clip!) maybe the problem will be solved.
I ran the self test on the unit and got no bad messages. In fact, after the self test it simply displays the same messages (888, etc) that you see when you start it up.
I still have my broken button '93 unit and I took a look at swaping the button face for the broken button portion of my '93. Some of the wires look hard wired to the board in the back of the unit, but maybe they will unhook in the front.
Questions - (1) can you put the front end of a '95 eatc on the back circuits and plastic box of a '93 unit?
(2) Is there some problem throwing a '95 unit into a '93?
(3) any speculation on the ridiculous outside temperature numbers (-7 to 15%)?
(4) Any insight on the self test results?
Thanks, Tom
Thanks, Tom
