bigpappy
Hey, gang.
I've got my car jacked up, with stands. I've removed the wire from the solenoid. (The solenoid moves within its housing -- that's a good indication I'm replacing the correct part.)
I've got the Chilton's manual, but it's a bit "generic" in its pictures and directions.
I'm sure I could remove the 2 bolts that are holding my starter in if I could see them and/or get a wrench on them.
Is there a nifty technique for dropping this bad boy out that one of you folks knows about and could share?
I searched the forum and found some useful stuff, but I must be doing something wrong, because I can't even see the bolts to get a wrench on 'em!
Thanks for any enlightenment that you can provide.
John
John
