nkb93
SLO 4 SHO
Here's the story: I tried installing Earl's SS lines from Jegs on the front last weekend to compliment the PBR calipers. I planned to do the fronts now since I was changing calipers anyway. I planned to do the rear ones later, as I needed to get the car out of my Dad's shop ASAP and back up to my house (3 hours away).
So I got the driver's front SS line on beautifully, no leaks whatsoever. The passenger side one, though, leaked under gravity flow where the hard line on the car meets the SS line. No matter how tight the plug on the hard line was tightened into the SS fitting, it would still leak, like it wasn't seating well. After taking the line off and inspecting it, you can see where the flare on the hard line was hitting where it was supposed to against the SS fitting.
Comparing the stock and SS lines, the threaded portion of the SS one where the hard line screws in is much deeper than the stocker. It felt kinda like the plug was running out of threads and not fully tightening down on the flare, although there was a thread or two left on the plug.
Anyway, I ended up putting a new stock rubber line on there that I had laying around, which worked fine. I really want to use the SS ones since I have them, but am a bit leery now. Anyone else have this kinda issue?
Sorry for the long winded post.. just can't figure out what's going on!
-Nate
-Nate
