2011TAURUSSEL
2014 SHO LMS Stage 1 V10
Well For those of you with the Performance Package at least through MY 2015 the SHO P/P stock wheels are Goodyear Eagle F1's. General recommendations are Summer Only but in DFW it is pretty much always summer. I received a set from Gregg9933 his 15 SHO P/P had the Eagle F1 but in Oregon obviously they wont last long even if traded out for the winter. He sent me His Eagle F1 and only cost me about $409 for shipping after he got the Continental DWS. Fast forward a little over 18 months and 25K...(ish) miles later went in for annual TX state safety/emissions inspection today. FAIL Tread depth and cords showing. Tech showed me the tires and I saw the cords also advised that rears were cupping which was reported to be advised to be residual damage from rear shock failure. I replaced shocks but about six months later when I got another daily driver. Service Advisor saw the cords showing and basically stopped the inspection there. Did not enter in data base and did not charge. I asked if I could bring OEM tires which had roughly 10-11K miles and were still built up in the garage. Simple tire swap since both sets had rims at most maybe reset the TPMS for the OEM tires. He was skeptical since they were technically used tires but explained the situation and agreed to allow for inspection. 20 Minutes to Inn/Out Burger Drive Thru 20 minutes home and about 20 minutes back I had the OEM wheels back at NTB. A Couple of hours later done. Failed emissions but I am about 99% sure that is the LMS Tune I forgot to reset to factory tune for inspection my bad!! Safety good tires good and I have a few options.
1. Run OEM rims....Flower Petal) until the OEM tires wear out.
2. Transfer OEM Michelins to the aftermarket Rims
3. Get new OEM Michelin Primacy's and install on the aftermarket rims. I am inclined to go with either option two or three the goal is to keep the OEM rims in decent condition if I ever have to trade in. Costco has the Michelin rotation for the $70 off set of four......They rotate between Michelin and Bridgestone and this time its Michelin's turn.
FYI the Eagle F1's had about 25K miles on them and used them in DFW two round trips to Central Pennsylvania roughly 8K plus the roads and weather around the DFW Metroplex. Reading reviews on Eagle F1 they are a soft rubber compound and although performance rated long term mileage is not expected. Apparently I was on the higher end of the service life scale at 25K....ish!! That comes with rotating every roughly 6K so I had initial install in January 2016 Rotate/Balance May 2016 R/B 9/2016 R/B 2/2017 and removed from vehicle. 8/31/2017. Initial install and three rotations not too bad and although I would probably not remove them if I had a P/P don't expect a lot of service life unless you are religiously removing them for winter and even then tire service life don't expect much more than about 20-25K. In addition to cords showing I was down to the wear bars and probably either at or close to Minimum tread depth which every state I have lived in so far with annual safety inspections is 2/32nds.
Summary: I got my $400 out of them but will most likely go back to the Prmacy's
