e-brake pedal pad
rdub315
Syracuse NY
Sorry, had no idea where to put this... anyone have a suggestion on where to locate a pad for the e-brake pedal? Been searching CL parts cars, ebay, etc. but I can't seem to find a match. Is the pad for a Gen 1 SHO interchangeable with a regular Taurus?
zoomlater
Seattle, WA
I would think it is the same between a regular Taurus and a SHO. I know they are for Gen 2's. They can be easily found in a Pull a part place if there is one near you. The trick is to find one that is not split. You can also post in the Want to Buy section as this is a pretty common part.
the pad where the foot depresses the pedal or the pad where it hits the brake switch plunger under the dash?
crystizel
