I will post a pic later (has a/f data):
Max wheel HP: 322
Max wheel torque: 256
HP topped out at 6700 rpms
9 psi @ 7K
Here's the bad:
3rd run, I installed the extension that put the cone filter in the fenderwell. As I hit about 6500 rpms, it started running rough. Let off immediately. On THAT run torque started diving around 5-6 K.
I doubt the adjustment caused that... rather something broke???!!!???
As I started home, it was running horrible! Exhaust sounded disgusting, loss of power. After a few miles on the interstate, it seemed to improve.
Also, transmission fluid started leaking as I started my second pull. Why? Does the tranny take stress on a dyno? After crawling underneath, it is dripping off the shifting linkage, also appears to be coming out of the shaft that enters the trans. behind the oil pan...???
What could possibly leak onto the cat. that is closest to the mufflers (unequal length SS hi flow Y). It was smoking...???
Ever since I installed the new belt and idler pulley on the blower, I hear an additional sound coming from the blower. Kinda like the belt pulsating
(not sure how else to describe it)
SO do the #'s look good for the amount of boost?
A/F dropped off the scale (somewhere below 10)from 5500-6500 rpms. Running pretty rich there.
Pic. soon to come.
Max wheel HP: 322
9 psi @ 7K
Here's the bad:
I doubt the adjustment caused that... rather something broke???!!!???As I started home, it was running horrible! Exhaust sounded disgusting, loss of power. After a few miles on the interstate, it seemed to improve.
(not sure how else to describe it)SO do the #'s look good for the amount of boost?
Pic. soon to come.
