DU41 question?
95Rudy
Wausau, WI
This may seem like a easy question and I have done a search on this but I cannot find anything. My question is that I'm not sure how to remove the the DU41 computer from my car. I've located it and everything but I'm either blind or there are no screws or nuts that are holding it in. Do I just pull it out or is there some secret to the madness?
rlw001
Reading, PA, USA
There is 1 screw/bolt behind the glove box that holds a white plastic mount. On the firewall there a 10mm (?) bolt that goes through a wiring harness into the computer. Once both of these have been removed you can take the computer out from the glove box.
95Rudy
Wausau, WI
Thanks for the help! :thumb: I just got the computer out though so your just a little late, thanks anyways.
