DRL's blinking!!
sho2see
sho2see
Baltimore, MD
Ok so past 2-3 days when my DRL's are on at night, my headlights will flicker or turn on off on/off on/off. When it does this i here a clicking noise right where the headunit would be.
So then i turn the DRL's off and turn the lights on manually. What happens i still here that clicking. Its not a constant click ( sounds like a relay) but comes here and then.
Any suggestions?
Thanks
Dno
Ishodu
Its either the module itself, they don't have a good history of lasting long. Or a loose connection. To access the module you will have to remove the inner fender on the drivers side and you will see a heat sink that is the module.
