Door locks, flashers, radio,keyless, not working
Ex3Cutioner8
Maine
I have a 1995 mtx sho,
it has a aftermarket radio and sub, that was professionally installed, incar speakers running through the factory amp, sup box has it's own amp(and worked find for 3 years)
one day the in car speakers stopped working, the sub worked fine(in the trunk)
so i took my radio out looked for anything wrong, did not find anything, put it back in and it did not have power anymore, took it out again and found a wire had fallen out of the plug in the back of the radio,(a yellow wire) it touched some metal in the dash:oops:,
i then noticed that my doors will lock but not unlock, dome lights don't work along with flashers, keyless entrey, who know what else,
when i press the unlock switch on driver of passenger side, the dash lights come on with the ignition on or off:confused:, running or not.
Any help would be great Thanks,
Ex3Cutioner8
Maine
I have checked the fuses, but more what i want to know is why when i press the unlock button my dash lights come on? and the door's wont unlock, when i press to lock the doors they lock and the dash lights come on..... i am thinking i shorted the (RKE) or something, my remote wont work or the keypad on the door, it's got me stumped:confused:.
trainguy1989
SHOtarted
Wichita, Ks
You may have blown your RAP Module. It is located in the the upper-left hand side in the trunk. It will have an antenna wire and three connectors running to it.
shoon
cliTaurus
Dawson Creek, BC
Had the exact same thing,
you probably fried your keyless module in the trunk. Unplug the connections remove the 2 torx screws and pull the module out. Sniff it to see if you smell anything burnt.
I was able to repair mine by soldering a jumper to where some circuit tracing broke.
