door lock?
1993shoguy
maine
My 93 sho atx if i lock the doors from my side locks them all besides the driver side same with unlock and the with the key pad it does the same unlocks all besides the driverside door any ideas?
jonheese
Used-To-Know-It-All
Fogelsville, PA
I speak no-punctuation-or-grammar-skills-stream-of-consciousness. Allow me to translate:
"I'm having a problem with my 1993 Ford Taurus SHO ATX, as follows: If I press the power lock button on the driver's side door, all of the doors lock except the driver's door. It exhibits the same behavior when I press the unlock button and when I use the keypad on the door: it unlocks all the doors except the driver's door. Does anyone have any ideas what might be causing my issue?"
Regards,
Jon Heese
hawkeye18
Sorta cares
Norfolk, VA
Oh.
Well in that case, either the lock solenoid in the driver's door broke (kinda unlikely, they are like the simplest thing ever), the rod going from the solenoid either broke or detached itself, or - like in my wife's car - the solenoid stud where it is bolted to the door broke off and is just hanging there inside the car. It would basically be doing pull-ups every time you locked and unlocked the door.
Also, Jon: Boo got shot?
