Door Lock Relays
billh
Moxee, WA, USA
My car (94 ATX) didn't come from with remote or keyless entry. The door locks will lock intermittently. This does not seem to be a problem unlocking, that feature always works. It is not the door switch, when they decide not to work, neither switch will activate them.
I am guessing that they are controlled by a relay or two. Anyone know the location of these relays? I had it in to a shop, the guy condemned the aftermarket Ford remote system I had installed, so I had this yanked. Problem still there.
I am to the point where I plan on just replacing all of the relays in the system. I just need to know where they are.
Thanks
Bill
jelloslug
Digital
Greenville, SC
There are no power door lock relays in the non-keyless entry cars. There is a Pink/Yellow wire that goes from the drivers side button to the passenger side button. Check that one for problems, if it's ok there is a Pink/Black wire that comes off the passenger lock button that goes to all the lock actuators, check that wire for problems. Those are the only 2 wires that could cause all the actuators to not work at one and for the unlock button to work all the time.
billh
Moxee, WA, USA
jelloslug:
Thanks!
