Door ajar light?
buechine
Ontario, Canada
Anyone know where the switch is that controls this light? I have checked all the door lights and interior lights go on and off like they should when the door closes. Is there another switch somewhere that turns this instrument cluster light on and off? If I can't figure it out I guess I will have to pull the instrument cluster and pull the light just annoying. Lately it's been coming on and off just depends on the weather.
Bryan C. King
Norton, MA
You must have a Gen III. Mine did the same thing, still does it every now and then. The switch is located in the door latch and could probally use a good spray **** squirted in the latch. I used some PB Blaster and sprayed it directly into the latch. Instantly the light shuts off now everytime I close the door. It might take a couple of times for it to work....
