Door ajar light on
Denny
Taurus Homeland
Atlanta, GA
The door ajar light stays on in the car. The previous owner told me he didn't know why. The doorhandle for the back passenger door on the driver's side is broken, could that do it? Or is there a sensor or connection I should be looking for?
Thanks in advance
1990 SHO
Stock
1992 3.8
16.9@81
RIP
SHOstopper
Burlington, MA, United States
my 90 sho does the exact same thing but on the passangers door im pretty sure it is just a sensor because when i lock all the doors and turn the car off the cabin lights go off, obviously the lights would stay on if it wasn't shut properly
white94sho
Berea, OH
Had a 92 that did the same thing, never found out why since my brother totaled the car. oh, I also have some parts left including the doors (4).
94shoboy
south shore, mass, usa
mine does it too, i think its because water got into the hole where my antenna used to be and shorted out the wiring inside the door jam. you can actually check each sensor and find out which one is bad, it takes a bit of patience and time tho. just keep 3 doors closed, remove the sensor from the one open door and disconnect the wires. when the light goes out, thats the bad conector. if it never goes out, then you have more then one bad one, so just buy 4 new ones and do them all.
Denny
Taurus Homeland
Atlanta, GA
What would these sensors look like on the door? Those black button things that are on the car that the door pushes on?
1990 SHO
Stock
1992 3.8
16.9@81
RIP
94shoboy
about 1/4-3/8" round metal thingy that pushes in when the door is closed. i forget where they are in the door jams, i haven't seen my doors in months. i can tell you exactly where later if you still can't figure it out.
93redATX
SHOForum O.G.
WI
I also had this problem, and it was on my back passenger door. Eventually, I tried just spraying some WD-40 on the switch for the door, and it has worked fine so far (since about this time last year). I would say try that first, it might just do the trick.
-Andy
'93 Red/Black ATX
"Nemesis"
"The Daily Driver"
-Coneless
-Red interior lights
-Fog light mod
-Pioneer DEH-1100 45x4 MOSFET Head Unit
-SHO lettering painted black
-SHO banner on windshield, SHOforum.com sticker on back window, bottom center
-Gen IV Taurus emblem on trunk
Just Added:
'89 Light Titanium/Grey MTX
"Aphrodite"
"The Project Car"
-K&N Panel Filter
-Poor Man's Ram Air
-Boxless
My Website: http://taurusshosite.8m.com/main.html
AIM:Juggalo53048
