notdrphang
Hi my name is Adam and this is my forst post on shoforum.com. I have been browsing around the site as well as shotimes.com because I am trying to get as much of the 60k done on my 129k 91MTX as I can. My waterpump bit the dust and I figured this would be the perfect time to replace everything.
I have almost gotten everything apart but I was wondering if you guys could provide me with as much info on getting the timing belt correct as you can. I have searched the board and the info was kinda confusing
I got my top timing cover off and the dot on the cam pulley was at about 6 oclock and the white line on the timing belt was at about 12 oclock. It pretty much perfectly lined up with the big timing mark at the top of the engine located behind the cam pulley. I dont know if the belt has ever been changed but it just did not look right to me compared to the guide on shotimes.com. Also there was only one white line on the top of the belt. What is the deal with that ? Was my belt even installed correctly? The car ran pretty darn good though.
I have been working on cars for a year or so now but I have never done a timing belt. I need as much info on what works and what does not. I get the general idea but there are some blank spots that need to be filled in. So if you guys dont mind explain it as you would explain to a child
One last thing, here is the way "I" understand the process.
I was going to turn the motor with the old belt on till the dots on the cam pullies lined up with the big marks behind the cam pullies. Then I was going to remove the old belt and install the new one with everything looking like http://www.shotimes.com/php-bin/images/22.jpg
I am also going to pull the crank pullies to do a new front main seal. Is the outter part of the crank shaft notched so the pullies will reinstall one way?
sorry for any crappy grammer I have been working on the car all day and I am very very tired. I need all the advice I can get.
Thanks,
Adam S
<small>[ November 08, 2002, 10:24 PM: Message edited by: notdrphang ]</small>
Thanks,
Adam S
