Doesn't start after warm up
Bizzy
Have you pulled your codes yet? If not, that would be the first place to start and it should give you a decent idea of where to begin.
Once that's done, if you don't get any errors for the sensors, you'll need to check the basics for all engines; air, fuel, spark. Just as an FYI, it's helpful if you give more details on what you're having problems with. ie: Year, ATX/MTX, and what the symptoms are. Does it crank and not start or does it not crank at all, etc.
Good luck!
revhardSHO
Seattle, WA
Are you having problems with your tach as well? CPS or CPK (both acronyms = crank position sensor) would be a likely bet.
