Does this sound like a bad master cylinder?
9
94ShoOff
Guest
Well the brakes on the 91' have been sticking ever since I bought it. It happens after roughly 30 minutes of driving. I'll come to a stop at a light and the brakes will slightly stick. Tapping the pedal a few times normally releases it. I was thinking it was the pins were frozen, but I have since changed my thinking. I finally noticed that the actual brake pedal is sticking. I can pull it back up a half of an inch and the brakes release.
Sounds like maybe the master cylinder, anyone else have a similar problem?
Steve
94'ShoMtx- too much time not enough $ (60K miles)
91'Sho- plus spoiler, po-po grill, Gen III chrome wheels(71K miles)
87'Grand National, 97'Ninja ZX7R
Wifes' rides- 93'ShoAtx(80K miles), 91'Corvette Conv.
ryana83
Nashville, TN , USA
Yes I have the same problems some times.
From what I remember, the brake booster can cause that problem. I am pretty sure that it is the culprit because my pedal sticks like yours and my brakes aren't messed up. The pedal just sticks some times and I have to move it back up a little with my foot.
SHO-T
West Mich
I have the same problem with a 91 as well. The peddle is slow to return, but the brakes are releasing. Anybody know why?
SHOZZZ
Welland, Ontario, Canada
I've got that same problem, I purchased that car that way and spent close to about $500 to get it fixed, they replaced the master cylinder with a genuine ford one (said it was heavy duty) worked good for a bit but it still does it slightly, but not as bad. I'm pretty sure its the break booster, so i was told by many other people. the guy who had this car before me had it bad it was warping roters...seems okay for now, but i know someday i'll have to replace the booster...
SHOMEUP
hanover park IL USA
On this subject i have this same problem- its ******* me off so much so i really need ot fix it- so its the brake booster i hear...well how hard is it to replace..and what does it consist of..and where is it located- i was about to put cobra brakes on the car but if thats not the problem ill wait and fix this first...thanx for ne help
Jake
91 Mtx
jthomas68
Area 51
Ahhh,the 91 SHO thread :)
As per SHOTIMES.COM,just get a spring mounted to the pedal arm to help pull it back up.It`s the brake booster.
qiksho
SHO Addict
Fargo, North Dakota
Definately the booster. I replaced mine about 10k ago. Big diference in brake effectiveness. Couldn't believe how I could drive with it like that. One other thing I bought an aftermarket one and it didn't come painted so I had to paint it before install. I didn't remove any brake lines from master cylinder just bent it out of the way, but...I wouldn't recomend this It took a lot of work to weasle the booster in that way. But I didn't want to bleed the brakes :)
qiksho
SHO Addict
Fargo, North Dakota
