Does it have Performance Package?
Rob Hay
I have seen some clues for telling if a late model SHO has the Performance Package (PP) but isn't there a build sticker on these that lists the option codes?
On other cars I have seen these and then once you know the code you are looking for it makes it easy.
So, my question, in two parts:
Is there a sticker like this on the SHO's (2015-2018). and where ?
What codes are for the PP? Probably one code for brake rotors, one for differential gears, etc.
Thanks for the rest help in educating myself.
Rob Hay
OK, I'm a little smarter, in 2013 it was listed as AACSA, performance package 1. But that isn't the code on the build sticker is it?
ridered74
13 and up the PP will have the alcantara steering wheel, that is the easiest way to tell on the newer ones.
krewat
Long Island
And, of course, the black grill surrounded by chrome. Police Interceptor has a black grill too, but no chrome, and is a different mesh pattern.
6500rpm
Extra coolers are the standard and possibly the larger diameter rotors are visual aids. The easy way would be to just call a dealer with the vin and have them check Oasis for 3.16 gear ratio (It's going to be on the first page as soon as they pull it up).
Edit-
EGADD= 3.16 FINAL DRIVE RATIO. Not sure if that's what's on the door sticker that Lostneye refered to below but it's definitely the RPO on mine in Oasis.
Lostneye
NY
2013+ all have the same size rotors.
I believe the door sticker has an axle ratio code but don't know what means what.
