do i need it
lowc
aka vapah lock
Quincy, massachusettes
not sure if this is right spot but here it goes im tryin to finish up my atx to mtx swap and right now im trying to put the pedels in and the damm vacume line that comes off the brake pedel is in the way do i need to use this or can i yank it out. i dont think i need it seeing as im not swapin the booster out or does it go somewhere else the one who pulled it out is not around today so cant ask him
thanks guys
Paul
93SHO24V
MN
Someone correct me if Im wrong but I am pretty sure the vaccum line you are talking about is the "apply brakes to shift from park" And since you are swapping out the ATX and putting an MTX in I dont think you would need it.
the vacuum lines on the clutch and brake pedal on the mtx setup are the ones that are used to disengage the cruise control, so yes you do need them.
