Dirk37
Mr. Resourceful
Being captain cheapass, I don't like to spend money on anything I might be able to make myself, so the other day I thought I'd take a shot at making some phenolic spacers. And for an hours work, they turned out pretty nicely!
I had some 1/8 cheap wood lying around my garage so I decided I'd put to use. First I took the gaskets out of my car and traced them on the wood.
Next I took a tiny drill bit and drilled pilot holes in each penciled section. Then I took a router and cut out the penciled areas.
I happened to have an extra intake at the time so I made sure it all matched up. Now I messed up on mine because its way larger than the actual holes. This is a problem because now there's sharp edges in the intake which cause turbulence. It's a little noticable at low rpms but it's not too big of a deal. Next time I make these I'm going to get the holes much closer to actual size.
I had to cut some sections out of the middle and trim the corners off because otherwise the spacers will hit the fuel injector connectors.
Finally install them and torque them until it's snug! If you find the car is idling high / running funny, it is probably leaking so keep torquing it little by little.
The thickness of the spacer moved the intake up and I ended up leaving out the side mount bolts because I didn't want to adjust the supports. I also relocated the engine ground on the back passenger side mount to one of the top end tank bolts.
Now even after driving hard the intake stays just warm to the touch :sun: I have noticed a little increase in low end torque and it really makes you feel the runners open! My theory is that at the high load high rpms the amount of air coming in cools the intake even more and thus you get more air and more power
