DIY Camber Adjustment??
NJSHO
Clean Your Shorts!
NJ
How can I change the camber on the front wheels myself? I tried taking all three nuts of the top and moving the plate but it wont budge. I then took the tire off the ground and I still couldnt move it. I have already drilled the welds out a couple of years ago. I just got an alignment(~2 weeks ago) and they were moved so I know that they are moveable. I hit a big ditch the other day and now my front wheels look like this /............| . Not that extreme but there is a visable difference. I was hoping to split the difference, because Im not sure which side is correct, and I dont think the alignment shop will do it again with out charging me (plus they are far away.)
Thanks
Slo-Sho
It wasn't me!
Crossroads, CNY
Something is bent. You could try taking a drift or a punch and hitting the plate to dislodge it. Inspect the strut!!
