SHOMAN24V,
I figured you needed $.02 more. Look in the factory shop manual for the recommended nuts and bolts that should be replaced, not reused.
For example, the pinch bolt and its nut, the axel nut, and if I remember right the nuts that hold the struts (on top of the strut towers), to name a few. The nuts that are recommended to be replaced are all "lock" type nuts, and are good for one use, and one use only.
When you re-attach the tie rod ends, use new cotter pins, as a safety precaution (cheap insurance). If you are spending that much money on the suspension, why not replace the lower control arms with new ball joints and bushings?
Well thats my $.02 (in 1959 $$$)rangerj
